620 steering idler
nzbidzel
620 steering idler
Post by nzbidzel »
managed to get one, however someone put a 3bolt one on inside the chassis rail
and pictures ive found on the net show the 2bolt one on the outside as well as inside, anyone
confirm which position I should bolt it to the rail
EDIT: Flag. the replacement PCD didnt work, so had a workmate machine up a replacement bush setup to rebuild an original 4 bolt that was flogged and given free
