90 deg ignition leads for a15
jeremiahnz
Datsun Driver
Post by jeremiahnz »
I need ignition leads with a 90deg fitting on the spark plug end to miss the supercharger.
Don't really know anything about differences in leads so was hoping someone could tell me if these should work with a15 plugs and dizzy cap
http://www.trademe.co.nz/782522074" onclick="window.open(this.href);return false;
1965 Bluebird 410
1976 Yamaha RD50
beaver
Re: 90 deg ignition leads for a15
Post by beaver »
As long as the connections suit the dizzyand the spark plugs then they well be fine
hsepwr
aka: Craig
Post by hsepwr »
I Sell msd leads for a v8 which will work mint they are 8mm black and come with a special tool for making the dizzy end and I can do a set for $65 delivered and they would be a much better quality than the auction on trademe you are looking at.
Proparts Napier
Craig
021 731 207
^^^This man will see you right.
jeremiahnz
Datsun Driver
hsepwr wrote:I Sell msd leads for a v8 which will work mint they are 8mm black and come with a special tool for making the dizzy end and I can do a set for $65 delivered and they would be a much better quality than the auction on trademe you are looking at.
Proparts Napier
Craig
021 731 207
Cool - thanks Craig. Will be in touch.
1965 Bluebird 410
1976 Yamaha RD50
