Laura's 240C
85_Z31
Re: Laura's 240C
Post by 85_Z31 »
Fantastic Car
Its awesome to see some of the big Datsuns getting a bit of a following in the last couple of years.
LittleBruise
aka: Laura
Re: Laura's 240C
Post by LittleBruise »
To be honest I never even knew about these old bigger styles until I came across this one, love it though!
Needs more low in the back, this is with two people sitting on the boot.
LittleBruise
aka: Laura
Re: Laura's 240C
Ok Christmas and holiday are over, time to get back to work on my beast. Few more issues now, pretty much won't start and move itself, very smokey. Think maybe new seals and rings? Who is a good person to take it to to figure out what is wrong?
tlssunny
aka: jesse
Re: Laura's 240C
Post by tlssunny »
ALL DEPENDS ON WHAT SIDE OF TOWN YOU ARE ON
LittleBruise
aka: Laura
Re: Laura's 240C
Selwyn/South side but don't mind travelling
LittleBruise
aka: Laura
Re: Laura's 240C
Am going to test the compression first to see what that says. Does anyone know what it's meant to be?
Re: Laura's 240C
Not off the top of my head.
but the important bit is to do it with the engine warm. And hold the throttle wide open while you're testing it.
They should all be without 10psi or so of each other. To check how worn the rings are, after the test, squirt some clean motor oil from an oil can in the through the spark plug hole. The oil will improve the seal, and if it's worn the oil should make the reading higher.
gman
aka: gman
Re: Laura's 240C
Post by gman »
Good comp on a 260 is 150 dry 165 wet .I have seen many running 100 dry comp and run well.
2 doors
Re: Laura's 240C
Post by 2 doors »
after test driving this for you, I would be surprised if the issue is rings etc, could just need a basic tune if its been sitting for a while, that motor ran like a swiss watch, and was very tempted to buy it myself if you hadn't.
LittleBruise
aka: Laura
Re: Laura's 240C
Thanks guys, I'll attempt it tomorrow but engine hasn't been staying on so might be tricky to warm it up to get it done. i feel like it's something little but I don't know what to look for!
