Braided brake lines for B310?
sunny79datto
Post by sunny79datto »
just picked my car up from wof place to get a small list..
Rear brake hose split
Left front brake hose split
Fuel line to secure (under body)....easy
Exhaust leaking..
so since got to replace the brake hoses may aswell do the lot
and was wondering if ya can get braided ones for them made up somewhere?
wana try get it sorted so i can make Akaroa :burnout:
Re: Braided brake lines for B310?
SafeRbrakes can make you new hoses no worries.
sunny79datto
yea had a few comments on anougher post.. think mite just stick with standard ones
get them then the dreaded job of replacing them and bleeding the brakes
chris_g1
Post by chris_g1 »
sunny79datto wrote:yea had a few comments on anougher post.. think mite just stick with standard ones
You need to replace them as you say they are split so you will need to bleed new ones up anyway so why not go braided at the same time?
We have two 1600's and both have braided lines and they are no harder to bleed up than standard ones and give a firmer feel to the pedal.
Standard ones bulge slightly being rubber so take some of the feel away.
Bleeding brakes aint hard Andy.
Do you have a compressor at your house? I have the use of a pressure bleeder which makes it even less work.
sunny79datto
yea replacing them will be easy, its just bleeding them is the part i hate
and yea now you say that think i will try look at getting braided ones
are they expensive? will replace the lot.
yea i have a small compresser in the garage Bart, whats this that makes it even less work?
i like the sound of that.
tlssunny
aka: jesse
Post by tlssunny »
you can get braided hoses made from a heap of places like safe rs, cv specs etc but why would you bother? bit of a w**k factor but thats just my opinion, yes the people are correct and it will increase better pedal pressure but most people wouldnt even be able to tell the difference. rubber brake hoses $60ish--- braided lines 50ish EACH
im sure you have better things to spend ya money on and if you are after better brake feel then put some good quality pads and rotors in the front end!!!!!!!!!
Totally agree with Jesse here, brand new rubber hoses are cheaper and will do the job just fine.
tlssunny
aka: jesse
Post by tlssunny »
theres some guy who works at a parts place i know of who might be able to sort you out with brake hose hahahaha
***appco for life aye????????
sunny79datto
yea went in their got a set of rubber.. asked about braided and they said tripple that price
so yip all rubber got them on now need a m8 to come over with a beer and help bleed them
hopefully get everything sorted before akaroa..
hate having my wof just before that but at the same time its good to know im going to be safe on that mish.
