After 1200 parts:
- left tension rod
- The rods that join the sway bar to the LCA (b310 ones are too big)
Front suspension parts
- Tony_Whenua
Naki-Fisher
- aka: Naki
Re: Front suspension parts
Quick question are the all the same size and Length?
- Tony_Whenua
Shit I dunno.Naki-Fisher wrote:Quick question are the all the same size and Length?
I'm assuming the sway bar link rods are different between B110 and b310 as the ones I got from Brocky were way bigger than the original B120 ones I had.
About the Tension rod ... I'm unsure.
Hoping people on here would know.
Naki-Fisher
- aka: Naki
cool my question was more for the tension rods
What size are the bolts that hold the castor rod to the lower arm?
- Tony_Whenua
the head of the bolt is a 17mm - is that what you wanted?
Yes.
That means that 110/210 stuff wont work.
So you need B310, or GB110 castor rods. As the early stuff was smaller.
Naki-Fisher
- aka: Naki
Now I'm lost
17mm meaning the nut on the end of the rod or 17mm the bolts to hold it to the arm that comes off the crossmember?
17mm head on the bolts which hold the castor rod to the lower arm.
- Tony_Whenua
bump .... Any one?
