What oil do you suggest for struts
funkydato
Datsun Dreamer
aka: Pickles
Post by funkydato »
I've heard a few different people using a couple of oils for reconditioning struts on a12, sunnys etc...
Any suggestions please guys. ;)
I need to recon mine thats all. :dance2:
chur :beer:
81 b310 Dato (everyday drive)
81 b310 Dato (in storage)
79 Sunny (project on-going)
Ministock (Green, 1200)
nick_m
aka: Nick m
Re: What oil do you suggest for struts
Post by nick_m »
I've heard of people using 20w50 engine oil to stiffen things up.
I couldn't find anything in my service manual about what oil to use but I think from memory its 30w. Could be wrong hopefully someone else will chime in
aka: leppa
Post by dirtyleppa »
is it really worth the hassle man? new shocks cant be all that expensive. i can get prices for them if needed
Dattodevil
aka: Damo
Post by Dattodevil »
some people find that the old hydraulic shocks suit the lighter 1200 better than using newer gas shocks.
Think iv heard someone use anti freeze? But not 100% sure on that
Brnwgn
aka: Hayden
Post by Brnwgn »
genrally standard they use a very thin hydraulic oil(10-30 or lighter), ive fitted engine oil in the past and its worked almost too well... feel all the bumps but the car handled well on the track... its cheap but i wouldnt bother as gas ones are well priced..
as for anti freeze i know alot of circuit guys use it in the strut around the insert as this helps disapate heat. very effective so im told..
taiparacer
Datsun Dreamer
Post by taiparacer »
i cheat i use motor cycle fork oil will try and find the container find it is the best but then again uim a cheap skate as i had a 4 litre pack given to me :D :D :D :D :D
