I'm having a bit of a clear out, I've got a lot of stuff, if there is something specific you need let me know and I'll have a look.
Some 280Z 2+2 interior bits - free if collected, there's some red stuff and tan stuff
I've still got a few 6 cylinder L series bits, L28 pistons & cranks, L20 inlet manifolds etc
I've got most of an NA FJ20 bottom end, the block has a broken alternator mount but would be good for mocking up etc, the crank is still in it and probably okay
RB bits, I've got a few bits and pieces, RB30, RB26 and some RB20 stuff including a whole NICS turbo motor that I want to move on
A set of VG30 injectors, unknown condition, removed from a very, very rusty Z31
Quite a few turbo bits, mostly VG30 stuff
Z31 front 5 stud hubs, I've got two sets of early pentagon style ones
Update:
Also found an XF Falcon throttle body
And I've got a pair of FD RX7 seats
A pair of 4 stud factory Z31 wheels as well, I think they're 15s?
Clear out
Re: Clear out
Much want for an FJ20..... Might be intrested in some L series stuff but I don't know yet.
- gman
- aka: gman
Re: Clear out
rb30 crank?
Re: Clear out
No sorry, last one went with the block.gman wrote:rb30 crank?
Re: Clear out
I've also got this sweet brand new L series turn buckle adjuster set which comes with an aluminium pulley for fitting a later model Nissan alternator to an L series.
Re: Clear out
Ooooooooooooooh that I could be interested in! Would totally deblingify that pulley too! What alts would that fit?
Re: Clear out
Could be keen on a turbo for LD28 - are they Vg30ET ones
Re: Clear out
Yeah, VG30ET and I think maybe some bits from an FJ20 one but they are basically the same turbo anyway.brocky41 wrote:Could be keen on a turbo for LD28 - are they Vg30ET ones
Re: Clear out
Pretty much anything newish as far as I know, RB, SR, VQ, etc etc. I can measure the pulley if need be but I think most of the shafts are the same.Datto_610 wrote:Ooooooooooooooh that I could be interested in! Would totally deblingify that pulley too! What alts would that fit?
