indicator lights 3 to 2 wires?
Tony_Whenua
Post by Tony_Whenua »
changed the old rusty front indicator lights to new ones ... prob is its going from 3 wires to 2.
What do I do?
Re: indicator lights 3 to 2 wires?
The fronts are park lights too aren't they?
Tony_Whenua
Yeah they are
mint16
aka: Brendan
Post by mint16 »
Taiwanese lights.
The extra wire could be the earth?
Tony_Whenua
I tried to follow the wires back but they go into the main cable ... didn't want to inspect to much further but will just get a volt meter and trial something that way.
datsunboy
aka: Dan
Post by datsunboy »
Yep. Third wire will be earth
Tony_Whenua
So I did some wire searching etc and found the indicator and park light wires and the third which goes all the way back into the firewall ... Going to just remove this wire completely or will this affect the system/circuit?
Do I need to loop this earth wire with any of the others?
Tony_Whenua
Tony_Whenua wrote:So I did some wire searching etc and found the indicator and park light wires and the third which goes all the way back into the firewall ... Going to just remove this wire completely or will this affect the system/circuit?
Update: each earth from both sides are linked together and go all the way back to the connection inside the firewall. I'm tempted to remove completely as I see no reason to keep...?
Have found and replaced a melted connection at the firewall too.
Tony_Whenua
main lights wont turn off
mint16
aka: Brendan
Post by mint16 »
Earth the earth wire, dont remove it.
Change as little as possible to prevent creating issues.
