Fuel pump
Ivan
aka: Ivan
Fuel pump
Post by Ivan »
Hi guys not to sure if any one can help. As not many of you guys have six's with webers carbs. Any ways what fuel pumps do you guys run with your set ups? Looking online at fuel pumps there seems to be so many different "styles" of pumps. At the moment I run a Facet pump and the spec's say 1.5-4PSI 12v 95 Lt per hour. Its in the lower end of the range and with the old engine set up it seemed to work well. With the new stroked out L28 (Only 100cc from what I worked out) It should still supply enough fuel to the motor .Also having a low psi rating I won't bother running a fuel reg. What do you guys think?
Datsun 260c
gman
aka: gman
Re: Fuel pump
Post by gman »
It should be fine. You wont need a reg webers can handle a lot more psi than dellortos.
