1200 Wiring Issues
b110sss
Datsun Dreamer
1200 Wiring Issues
Post by b110sss »
Guys,
Murphy's law- car booked in for a WOF tomorrow after being off the road for months with a front end rebuild and after hooking up the horn the damn thing refuses to work!
If I run a wire to the battery it works.
The fuses in the fuse box all look good.
Nothing doing at the steering wheel horn button in the way of power.
And I haven't been fiddling with anything in the wiring dept.
Any ideas of where to look?
Dave
Re: 1200 Wiring Issues
IS the connection at the brush under the steering wheel dirty or worn. Possibly though it is the relay playing up, although it should still supply to the wheel I think, this is where I'd look after checking the brush at the steering wheel.
b110sss
Datsun Dreamer
Post by b110sss »
Hi Vaughan,
The steering wheel wiring appears to be fine. I'm pretty sure that I've got a spare relay at work so will try that.
Thanks for your help.
Dave
