carby problems?
fletcherj1
- aka: fletch
carby problems?
Hi my car starts fine but after 10 seconds it will die. If I pump the throttle quickly it will keep the car going but as soon as I hold the throttle on it dies. Anyone know what it could be?
Re: carby problems?
Possibly an accelerator pump problem.
Re: carby problems?
Also check float level, make sure enough fuel in the bowl
Re: carby problems?
had same symtons a lil while back, mine was a air leak in the fuel line, grab a new $10 fuel filter thats see thru (doesnt hurt to replace every 6-12mths with these) if air leak youll see bubbles come thru the filter.
if air leak, grab $15 worth of new rubber fuel lines a couple new clamps (optional) and replace all the rubber line from fuel pump to fuel tank
Re: carby problems?
Could also be an air leak somewhere else in your carb/manifold.
