Does anyone know a radiator that I might be able to use in my 620?
I need one with the bottom outlet on the side instead of sticking straight out. This is because with my new engine, it points straight into the fan.
I know that the 620 and sunny radiators look similar if that helps anyone.
I can adapt things and make brackets etc. so doesn't need to be a perfect fit.
620 Replacement radiator ideas
- tlssunny
- aka: jesse
Re: 620 Replacement radiator ideas
you can always get like a early rx7 radiator because they are short in height and then get the hose outlets modified.... i always buy honda radiators and get the hoses modified and get bungs welded in for senses and switches etc
Sweet, I will have a look into that.
Or else does anyone know someone around who could custom make a radiator in the Tauranga area?
