32/36 Weber onto A15
1200 Koozer
Regular
Post by 1200 Koozer »
Any build threads on installing a 32/36 Weber onto A15. might need to extend throttle cable. Any advice? ?
Re: 32/36 Weber onto A15
YOu can buy an off the shelf adapter to fit them.
You'll want to fit the throttle wheel (The bit that the accelerator cable attaches to) to the weber carb. Once you get started, it's pretty easy. The rejet is the tricky bit.
