H190 LSD
- blitzballa
- aka: James
H190 LSD
So I am currently running a H165 diff with a phantom grip LSD but was wondering if anyone has or knows of how the H190's go. Preferably I would like an LSD as well and have looked at some of the Nismo options as the Detroit Lockers appear to be only good in a straight line. Is there much work needed to fit an H190 into a B310? Also on a side note, what happened to Phantom Grip? Do they still exist?
Re: H190 LSD
I don't know if you'll find an H190 which is a straight bolt in to your B310.
The LSD's do pop up on Yahoo from time to time. (I know three guys who have bought them off there)
Also ratios with a smaller number than 4.1:1 are a little thin on the ground.
Re: H190 LSD
240RS's ran an H190 in a S110 Chassis which shares a floor pan with a 310. I understand some other of the S110 family ran H190s also. But as Bart says, not easy to come by.
- blitzballa
- aka: James
Re: H190 LSD
Good to know about those S110's sharing a floor pan thanks. I think I might just stick with my H165 for now and purchase this H190 I found and just work on getting it to fit slowly. I found another outfit related to Phantom Grip that build an LSD kit for the H190 so might have a yarn to them as well. Still wondering if anyone currently runs an H190 in the club or if not what sort of engine packages people can run with an H165.
Re: H190 LSD
I have an h190 lsd i got from Japan. Ina modified vanette housing. works very well and is significantly bigger than the h165. I have a ca18det engine and its handles the power no problem. (when it was going 3 years ago its hard to remember haha)
