R180 Diff help needed
Jabo
aka: Jasper
Post by Jabo »
So im currently in the process of making my LSD from a Subaru diff and my diff. I need to get the LSD Centre out of the subaru diff so I can change the crown wheel but I Cant figure out how to get the outer bearings off so the centre will slide out.
please some one help
Chur
Re: R180 Diff help needed
I think that you have to undo the side plates. The bearing cups are pressed into them. With both of them removed, you should be able to wiggle and jiggle the center out.
Unless you are replacing the bearing on the lsd bit, make sure you keep the bearing cups matched up to their respective bearing.
kartboy
aka: Hayden
Post by kartboy »
I heard a rumour that you were beyond help..lol
Jabo
aka: Jasper
Post by Jabo »
Thats true I am beyond help but my diff isnt. thats what I thought Bart but I dont see any way the centre will come out with the bearings attached to the sides theres not enough room... Ill have another go later
Godzilladat
Post by Godzilladat »
As bart said, just use a pry bar to lever the centre out once you have removed the 2 bearing holders (4 bolts).
