Rust certification
blitzballa
aka: James
Rust certification
Post by blitzballa »
Finally getting around to getting the Sunny's rust taken out and I was wondering if I needed to get cert done for it? There is no record of it ever failing Wofs on rust issues and the car is rego on hold so doesn't need the hellish re-vinning/compliance.
2 doors
Re: Rust certification
Post by 2 doors »
you can go ahead and do it yourself, seeing as its not been noted on a computer anywhere. just make sure you do a good job, and its not obvious when you go for a wof
blitzballa
aka: James
Sweet thanks. The more obvious bits are getting done by a certified rust/panel beater and then the car will be completely re-painted anyway so it should be easy enough to hide.
