Hi,
I have a 1974 Datsun 120Y (A12) with Twin Dellorto's and a Redline Inlet manifold and am having trouble finding suitable extractors. I guess I have four options here:
1. Get a different inlet manifold (and hope my linkage gear fits)
2. Get a new prefab exhaust (apparently Hurricane in .au make one, haven't been able to find which model suits best though)
3. Get a new exhaust custom built (expensive)
4. Modify my current Coby D2 to fit somehow
Does anyone have any bright suggestions for suitable inlet manifolds or exhausts.
1974 Datsun 120Y with Twin Dellortos
Re: 1974 Datsun 120Y with Twin Dellortos
most of the manifolds ive seen, are on a slight upward angle, the angle allows the bottom of the inlet manifold to clear the extractors, I would suggest trying another inlet manifold, maybe someone near you could lend you one??
That would be awesome if someone had one lying around I could try out. There will be beer in it for you
- gman
- aka: gman
Take the manifold off and you shave 2mm off the face on a angel this will lift the carbs and improve air flow and clears extractors.
Ended up getting an inlet mainfold from Palmside here: http://www.palmside.co.nz/product_pcid_15842.html" onclick="window.open(this.href);return false;
Also ended up getting the engine re-built and bored out to 1330cc
Body is pretty straight too
Looks good, Nice to see another one getting the A Series treatment. Be good to see some more pics. How does it run?
very nice. what pistons did you use? must be 78mm bore?
- tlssunny
- aka: jesse
how'd you get it too 1330cc?????????
