Page 1 of 2
1974 Datsun 120Y with Twin Dellortos
Posted: Thu May 07, 2015 10:22 pm
by bogannz
Hi,
I have a 1974 Datsun 120Y (A12) with Twin Dellorto's and a Redline Inlet manifold and am having trouble finding suitable extractors. I guess I have four options here:
1. Get a different inlet manifold (and hope my linkage gear fits)
2. Get a new prefab exhaust (apparently Hurricane in .au make one, haven't been able to find which model suits best though)
3. Get a new exhaust custom built (expensive)
4. Modify my current Coby D2 to fit somehow
Does anyone have any bright suggestions for suitable inlet manifolds or exhausts.
Re: 1974 Datsun 120Y with Twin Dellortos
Posted: Thu May 07, 2015 10:28 pm
most of the manifolds ive seen, are on a slight upward angle, the angle allows the bottom of the inlet manifold to clear the extractors, I would suggest trying another inlet manifold, maybe someone near you could lend you one??
Posted: Thu May 07, 2015 10:54 pm
by bogannz
That would be awesome if someone had one lying around I could try out. There will be beer in it for you :)
Posted: Fri May 08, 2015 4:34 pm
by gman
Take the manifold off and you shave 2mm off the face on a angel this will lift the carbs and improve air flow and clears extractors.
Posted: Sat Sep 19, 2015 10:56 pm
by bogannz
Ended up getting an inlet mainfold from Palmside here: http://www.palmside.co.nz/product_pcid_15842.html" onclick="window.open(this.href);return false;
Posted: Sat Sep 19, 2015 10:59 pm
by bogannz
Also ended up getting the engine re-built and bored out to 1330cc :)
Posted: Sat Sep 19, 2015 11:04 pm
by bogannz
Body is pretty straight too :deadhorse:
Posted: Sun Sep 20, 2015 9:08 am
Looks good, Nice to see another one getting the A Series treatment. Be good to see some more pics. How does it run?
Posted: Sun Sep 20, 2015 2:11 pm
by nzdatman
very nice. what pistons did you use? must be 78mm bore?
Posted: Mon Sep 21, 2015 8:11 am
by tlssunny
how'd you get it too 1330cc?????????
