Ball joints etc
Tony.buchler
Datsun Dreamer
aka: Tbag
Ball joints etc
Post by Tony.buchler »
Hey guys, I've just stripped my steering assembly and am on the hunt for all new joints and bushes. Has anyone got a diagram of I can use to reference part numbers? Are the joints at either end of the cross rod replaceable? I see one has a scrub screw in it.
Also, where is the best place to buy the rest of the ball joints, bushes, boots etc?
Tony.buchler
Datsun Dreamer
aka: Tbag
Re: Ball joints etc
Sorry, on a 1200
buzzy
Datsun Driver
Re: Ball joints etc
Post by buzzy »
http://datsun1200.com/modules/mediawiki ... rt_Numbers" onclick="window.open(this.href);return false;
Tony.buchler
Datsun Dreamer
aka: Tbag
Re: Ball joints etc
Shot man, thanks
_smp_
Regular
Re: Ball joints etc
Post by _smp_ »
Just done this a month ago myself, good times :lol:
BNT will sort you out for all the parts except the outer tie rod ends. You can try ADL for the outers.
Also the cross rod bar will need to be taken into ADL for them to suss out a replacement.
Chances are you'll need the smaller ball joints... BJ92 are the go.
Check out the idler arm for pitting and perished bushes, nolathane does an easy replacement.
Lower control arm bushes will need a bearing press or a gas torch to take the old rubber bushes out.
I gave up on my tension rod bushes but will try again in a month or two and prob machine the rod to get some adjustment going.
Looking for a 510 at the mo
lost loves
1x KB110 - recently gone to a good home
2x P510 Deluxe
1x P510 SSS
1x P510 Wagon
Tony.buchler
Datsun Dreamer
aka: Tbag
Re: Ball joints etc
Ah... Just the info I was after, :D
Legend.
:beer:
Evil13
aka: kane
Re: Ball joints etc
Post by Evil13 »
I got everything from bnt except for the cross arm joints
1200 sedan
1961 ford galaxie
grant76
Re: Ball joints etc
Post by grant76 »
Cross rod/ draglink can be bought new off eBay using the b210 rod. Looks slightly different but fits fine. About $80-90 plus postage
_smp_
Regular
Re: Ball joints etc
Post by _smp_ »
good to know the cross rods are in Ebay...might have to take a look.
here are the part numbers...from BNT. The larger ball joints (BJ176) are for the later models. I found the BJ92 suited my 1972 coupe.
I founds that BNT didn't have the inner tie rods...and ADL had a bit of trouble getting the left hand threaded ones...
The guys at Penrose are on to it though. The ADL part numbers for the inners are SE-4142L and SE-4142R. they are listed for the 120Y (B210).
check out my idler...thought it was totally fooked, but it just turned out to be just 43 year old plasticky bush :tits:
lost loves
2x P510 Deluxe
1x P510 SSS
1x P510 Wagon
Re: Ball joints etc
Every single datsun I have ever owned has eaten a set of idler arm bushes.
