Recaro fishnet seat
Garth
Recaro fishnet seat
Post by Garth »
Do any of you cool cats have an individual recaro fishnet in good condition that you want to sell me cheapish? Only need one. One of my ones reclines itself when I hit those high boosts. Unless someone knows if you can fix this issue. Chch ideally
Re: Recaro fishnet seat
Uncle Mig would fix it wouldn't it Garth.
Garth
Post by Garth »
classicdat wrote:Uncle Mig would fix it wouldn't it Garth.
Any rules around fixing them in place with mr mig? Not worried about replacing it because the one in question is pretty poos with rips also
joebem
Post by joebem »
There is a guy out rangiora that wrecks big horns etc (Google it)got a set off him for 150. if you end up with a spree side cover il be keen on one
cul8r
Regular
aka: Chris
Post by cul8r »
Use polyphonic washers (like the type used in sink taps)
I fixed nicoles and my own. If there's some washer left in there, you can sometimes get away with putting a steel washer in behind to pack it out. Ive also seen foam packed in there before too.
Both sides of the seat where the hand adjusters are - undo the phillips heads holding them on unless you've the Rotor style ones which pull off.
Garth
Post by Garth »
Sweet thanks for that. Seems to have got it sorted!
