WTB H165 diff flange
In need of one so i can get my driveshaft made up. Let me know if you have one for sale or know of anyone with one
Re: WTB H165 diff flange
Don't quote me and I know it sounds Bazzar, but I think I used a Cortina one on mine, Not sure they are any more available than Datsun ones, but it might help you out.
I could be wrong it was probably before you were born, so that means it was along time ago and my grey matter ain't that young.
- tlssunny
- aka: jesse
so you want the bit on the driveshaft or the bit on the diff head?????????? I possibly have
flange on D/shaft to bolt to diff if that makes sense?
this end of the D/shaft not the gear box side
- tlssunny
- aka: jesse
iam pretty sure on the Datsun1200 website that it says h150 and h165 are the same bolt hole measurement and alignment flange size its just one is round and one is square in shape. and there are plenty of h150 stuff around, I have a few driveshafts I would cut up for you.
let me know the size and I will confirm with you etc
cheers
cheers
yep H150 and H165 are the same so I guess either will be ok, bolt measurements are 45 x 54 mm. Inner circle 57 mm
