Is there anyone on here that is able to cut me out a flange in 8-10mm alloy if i provide them with a gasket,
Im not to clued up on this stuff so don't know what is best to use water laser gas etc etc.
Its only about half the size of a $5 note so quite small,
Willing to pay what ever is the normal rate. Just thought id ask on here before going to the phone book.
Brett
Profile cutter wanted,
- Datsun Mad
Re: Profile cutter wanted,
i work at a laser cutting place to bad your not in auckland could of done it for you
and most likely 8 or 10mm ali would be water cut
- Datsun Mad
I don't care where i have to post it to,
What is it? I can cut one out on the mill for you.
- Datsun Mad
Its a IACV flange so i can mount a IACV on my intake manifold and then have some sort of idle control,
Do you want to PM me the address then i can send it down to you,
Thanks
Brett
Thanks
Brett
