hi ya,
I have a A15 I'm working on as I'm almost ready to install with the 5 speed I had a couple of questions..
1. I understand there are different brass bushings of some sort that go on the gearbox shaft and these have slight size differences depending on a 'factor'. What size bush do I need to fit the A15 to the 60A gearbox? does it change size depending on whether I have the additional spacer plate between the two?
2. Does anyone have a clutch fork for the 5 speed and spring they would part with?
3. Still looking for a manifold from A15 head to twin dellortos-cant find the guy who used to sell on TM?
thanks in advance
matching A15 to 60A 5 speed
Re: matching A15 to 60A 5 speed
All A series spigot bushings are the same. AFAIK.
- tlssunny
- aka: jesse
I have new brass bushes at home, only 1 size for a series
yes I will also have fork and spring too
the guy selling them new off trademe was philspeed in chch for about 340ish that's the only new ones on there I think
Palm side have manifolds listed on their website
Zdog
- aka: Puke
yeah ive seen palmside although I can get them cheaper through oz direct. Had hoped to track down philspeed for the cheaper option. will try and Pm him.
Thanks tls sunny il PM you now.
