I arrived in NZ 2 weeks ago and got a good deal on 1200 sedan here in ChCh. There are few bits missing or that I want to change. So I am looking for - ignition, door and boot locks with keys. Complete cigarette lighter and wiring, and a choke cable. Also looking for standard U bolts, as car is to low and stiff.
All help appreciated
Bits n Pieces
Re: Bits n Pieces
B310 locks will fit if you grind one of the anti rotational keys/tanges off the the door lock barrel. Makes finding a bit easier.
Pretty sure there's quite a few brand new datsun locks on eBay too.
- tlssunny
- aka: jesse
Re: Bits n Pieces
I will have b310 locks if you go that way
Re: Bits n Pieces
Thank you Luke for the U bolts.
Must also give a big thanks to Luke for offering to lend me his tools to save me buying some to do the job. Then he says use the drive way. Then Warrick turns up and there are 3 of us transplanting u bolts.
Awesome fella's thanks for your time
