Hi all,
I'm after on of these water outlet pipes. Normally they have two outlets, this one has three.
Not found on 240z's or 260z's as far as I am aware. Maybe on 280ZX's.
If you have one you wish to part with, please get in touch via PM.
James
WANTED - Water outlet pipe
- 240znz
- aka: James
Re: WANTED - Water outlet pipe
280ZX's don't have them. What are the outlets for? Something to do with the carbs?
- 240znz
- aka: James
This is for a Arizona zed guy, so jo doubt some USA smog emissions boat anchor stuff.
- gman
- aka: gman
Pre heating the oil at the oil filter I have got some somewhere.DJZ wrote:280ZX's don't have them. What are the outlets for? Something to do with the carbs?
Really? It's on the wrong side of the motor. Pretty sure the L20 setups I've seen use the hose running from the lower radiator hose outlet to the back of the motor.gman wrote:Pre heating the oil at the oil filter I have got some somewhere.DJZ wrote:280ZX's don't have them. What are the outlets for? Something to do with the carbs?
- gman
- aka: gman
All the p90 heads had this that I now of but don't hold me to it.DJZ wrote:Really? It's on the wrong side of the motor. Pretty sure the L20 setups I've seen use the hose running from the lower radiator hose outlet to the back of the motor.gman wrote:Pre heating the oil at the oil filter I have got some somewhere.DJZ wrote:280ZX's don't have them. What are the outlets for? Something to do with the carbs?
- 240znz
- aka: James
If you have one that you can give away to a good home, let me know.
The chap who has asked for this sent me two clips that hold the rear tail light embellisher from the US. What a good rooster he is.
Cheers chaps.
Cheers chaps.
- gman
- aka: gman
James I will have a look.240znz wrote:If you have one that you can give away to a good home, let me know.
Cheers chaps.
- fletch
on a similar subject, where can i get the 2 bolt thermostat cover/top hose fitting as pictured in the bottom right of the top photo?
- 240znz
- aka: James
repco will have them
