Page 1 of 2
WANTED - Water outlet pipe
Posted: Wed Apr 20, 2016 12:04 pm
by 240znz
Hi all,
I'm after on of these water outlet pipes. Normally they have two outlets, this one has three.
Not found on 240z's or 260z's as far as I am aware. Maybe on 280ZX's.
If you have one you wish to part with, please get in touch via PM.
James
Re: WANTED - Water outlet pipe
Posted: Wed Apr 20, 2016 7:07 pm
280ZX's don't have them. What are the outlets for? Something to do with the carbs?
Posted: Thu Apr 21, 2016 7:45 am
by 240znz
This is for a Arizona zed guy, so jo doubt some USA smog emissions boat anchor stuff.
Posted: Thu Apr 21, 2016 5:30 pm
by gman
DJZ wrote:280ZX's don't have them. What are the outlets for? Something to do with the carbs?
Pre heating the oil at the oil filter I have got some somewhere.
Posted: Thu Apr 21, 2016 7:04 pm
Really? It's on the wrong side of the motor. Pretty sure the L20 setups I've seen use the hose running from the lower radiator hose outlet to the back of the motor.
Posted: Thu Apr 21, 2016 7:15 pm
by gman
All the p90 heads had this that I now of but don't hold me to it.
Posted: Thu Apr 21, 2016 7:34 pm
by 240znz
If you have one that you can give away to a good home, let me know.
The chap who has asked for this sent me two clips that hold the rear tail light embellisher from the US. What a good rooster he is.
Cheers chaps.
Posted: Thu Apr 21, 2016 7:58 pm
by gman
240znz wrote:If you have one that you can give away to a good home, let me know.
Cheers chaps.
James I will have a look.
Posted: Thu Apr 21, 2016 10:08 pm
by fletch
on a similar subject, where can i get the 2 bolt thermostat cover/top hose fitting as pictured in the bottom right of the top photo?
Posted: Fri Apr 22, 2016 5:50 pm
by 240znz
repco will have them
