When purchased it was mechanically in a bit of a sad state. Since then I have dropped in a tidied up J15 and gearbox, electronic ignition, new radiator, new fuel pump, New clutch kit. Has a new heater core and the heater box has been tidied up. Runs like a dream. Door window seals and weather strips have been replaced with new ones.
The white walls are just rubber insert that fit under the bead. These will probably be removed as they ideally would need replacing or proper white wall tires installed.
Come view to give it a good look over
Make an Offer
Any questions just ask.
