S110 / Silvia / gazelle solid axle rear disc brake calipers
Flauski
Post by Flauski »
As per title, both sides required and brake lines and handbrake cable if possible! PM me... Thanks.
mint16
aka: Brendan
Re: S110 / Silvia / gazelle solid axle rear disc brake calip
Post by mint16 »
Can you rebuild the calipers you have?
BNT for caliper seal kits....
Have a new toy Tony????
nzdatman
Post by nzdatman »
How much are those parts worth?
Flauski
Post by Flauski »
Can't rebuild things I don't physically have :)
Had a sunny for a good while now Greg, just not on here so much.
Dunno nzdatsun, do you have such items? Let's talk. :)
Maybe try that bloke Ethan Nemis Neame on FB. (IDK if he's on here or not?)
He has a baddass FJ20 S110. People with a given model of a car usually know who/where parts are for them.
You sticking an S110 diff under it Tony? (I heard they bolt in?)
Coupe or sedan?
Flauski
Post by Flauski »
Thanks Bart, yes I have a S110 diff, h165 and yes it bolts in, even has same length arms and a sway bar. It is about 20mm wider than the factory H150 in my b310 sedan
Flauski
Post by Flauski »
Bump still looking
brocky41
aka: Brocky
Post by brocky41 »
Have you got discs - need to know the width ie 10mm solid and diameter. I can look on the system at work to have a look what nissans runs a similar thickness / diameter on the rear as something from another model may work - like primera or r31 etc - just a thought
Flauski
Post by Flauski »
Cheers Brocky
257mm diameter, solid disc approx 9mm thick, 47mm height
Locked
