So I have a camshaft from kelford which states 2500 to 6500rpm, I would like to think it would pull to 7. Specs on my build thread http://www.nzdatsun.com/forums/viewtopi ... &start=100" onclick="window.open(this.href);return false;
85 pound valve springs from Franklin Camshafts Auckland (often ran in the ministocks up to about 7200rpm)
A15 head which will be skimmed down a bit, depending on valve clearances.
I am at the point where I need to decide on flywheel lightening? To or not to, I believe I can put a 9.5kg a12 one on (standard a14 is 10.7kg apparently), ill need to remove the engine plate to compensate for the thinner a12 flywheel.
How light is too light? I mainly drive by myself, 5 speed box
How/is it recommended to dowel the flywheel, I have heard a few stories. Unsure who would do this for me.
