Can anyone enlighten me as to what is the best option for a driveshft for my 1600 will be??
I have heard of using a navara driveshaft, but what model??
Driveshaft for a P510 running a S15 SR20DET
acustx
classicdat wrote:Steady progress beats periods of rapid progress broken up by dicussions with members of local Law inforcement
datsunboy
- aka: Dan
Re: Driveshaft for a P510 running a S15 SR20DET
yeah when I got mine done, the driveshaft guy told me I should use a 2WD Navara driveshaft.
he had one spare at his shop, so I dont know the exact model......
acustx
Thanks,
Does anyone know an exact model??
510BRE
- Area Reps
- aka: shane
hey greg i used my standard 1600 driveshaft and just had it shortened datsun 1600 gearbox yoke fits into sr gearbox
The 510 driveshafts are pretty spindley though.
acustx
Yea, I think I would rather up grade for piece of mind and further upgrading of power.
A drive shaft from an auto B310 would work with a little shortening. They use much larger tube than the 510's and they have replacable unijoints. Plus they use the same input yolk as an L series. (As far as I know, they are the same as the SR?)
- mint16
- aka: Brendan
like shane said, 1600 driveshaft yokes fit into sr gearboxs, i was looking at fitting a 1600 driveshaft, but decided against it a while ago.
unlimitedpower
- Datsun Mad
I used a beasty drive shaft i found from somewhere may have been a hilux i think.
Then i uses a Auto cerfiro yoke (same spline as a 6 speed) Tony Whiter wanted my 6 speed drive shaft for some reason so we did a swap. Then i used a R31 or R30 or what ever it was that matches my diff on the other end got an engineer to weld it up for a cashy and works mint as. Mite get it balanced one day but he said hes never had to get one done (does alot for the rally guys) and ive spun it up pretty fast in 5th and it doesn't seem to vibrate so all good so far.
