Cams 1973 Datsun 1200 Coupe
Picked up my b110 coupe back in 2015, started working away on it after only a month of owning it, wanted it painted up and looking nice so i decided to strip her back to bare metal and remove all rust
Re: Cams 1973 Datsun 1200 Coupe
1st job was the rust in the drivers door !
Nice job , have you considered removing the skin from the frame to allow you to planish the weld from both sides , it's not to difficult if you take your time , then you can wheel the repair back through the English wheel and have a file finished repair. Keep the progress pictures coming.
Havn't thought of that, was contemplating removing the skin and making a new one and then welding the handle piece on but wanted to keep as much of the original metal there as possible, ome day if the car ever ends up getting a good dent i might do what you said but for now a little filler will be fine, cheers for your input
Nice work, looks like you know what you're doing. Keep it up.
If you wanted to make a new skin I have a pair of dies I made for my pullmax that does all the top profile in one go, check out my build thread 2 doors 2 door, I made new skins for mine. where are you working ? sounds like you have some decent gear at your work.iamkiwiana wrote:Havn't thought of that, was contemplating removing the skin and making a new one and then welding the handle piece on but wanted to keep as much of the original metal there as possible, ome day if the car ever ends up getting a good dent i might do what you said but for now a little filler will be fine, cheers for your input
Cheers mate always heaps to learnbroke wrote:Nice work, looks like you know what you're doing. Keep it up.
Blackwells panel and paint, have had a lot of help at cpit (now called ara) from craig ericksen, will have a look now
Say hi to Craig for me, he knows me as Warrick , on marshland road. Your in good hands if he's helping you.
You beating guys make all this rust work look easy - i must have a go at this lol.
Great project, i like the amounts of steel that are going back into this - keep it up.
