A14 HELP NEEDED !!
iamkiwiana
A14 HELP NEEDED !!
Post by iamkiwiana »
Hi all, I have an A14, it came out of an sgx b310, the vin stated it was the 80hp model, but it is a round port h72 ?? is there any differences to the block between the higher and lower hp model A14s? or just the Head ? As I have an h89 head I was planning to put on the block, would this bring a lower hp engine to be the higher hp model? and what modifications would be needed for the head swap ? Thanks for your help :pc:
Josh
aka: SeEn-ThE_lIgHt
Re: A14 HELP NEEDED !!
Post by Josh »
Maybe variation in piston?
Block should be the same
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
The blocks will definately be the same.
Most A14's Ive seen had the open combustion chamber H75 (or H72?) heads.
your H89 should be an improvement.
I would think the cam will be different also, as the low horse power was an economy engine.
RedVB310
aka: RedVB310
Post by RedVB310 »
How do I find out what head is on my b310s a14, it goes like stink and one of the previous owner's built it, but I have no clue what the head is or what internals it has as the cam is lumpy as and it revs out to 8. Where do I check what head it is?
Sent from my E5823 using Tapatalk
kb110
Datsun Dreamer
Post by kb110 »
Remove the rocker cover and you'll find a casting
RedVB310
aka: RedVB310
Post by RedVB310 »
kb110 wrote:Remove the rocker cover and you'll find a casting
Cheers ill look tomorrow as I'll be taking of my intake manifold too to see if im oval port or round port as im looking at going twin carb
No need to remove MAnifold to check ports. Oval ones have a water jacket on the bottom of the manifold and are much deeper in the manifold, post up pics if you want, I am sure you will get opinions on which it is without tearing it apart. A pic of the casting will identify it also I would think.
RedVB310
aka: RedVB310
Post by RedVB310 »
Sweet as man I post pictures when I can, didn't have a chance today because of the rain
RedVB310
aka: RedVB310
Re: A14 round port or oval?!
Post by RedVB310 »
Hi guys I havw taken some pictures to see if you can help identifying what sort of ports my A14 head has on it and what head it actually is.
