Page 1 of 2
A14 HELP NEEDED !!
Posted: Sat Aug 12, 2017 4:07 pm
by iamkiwiana
Hi all, I have an A14, it came out of an sgx b310, the vin stated it was the 80hp model, but it is a round port h72 ?? is there any differences to the block between the higher and lower hp model A14s? or just the Head ? As I have an h89 head I was planning to put on the block, would this bring a lower hp engine to be the higher hp model? and what modifications would be needed for the head swap ? Thanks for your help
Re: A14 HELP NEEDED !!
Posted: Sat Aug 12, 2017 7:23 pm
by Josh
Maybe variation in piston?
Block should be the same
Posted: Sun Aug 13, 2017 8:57 pm
The blocks will definately be the same.
Most A14's Ive seen had the open combustion chamber H75 (or H72?) heads.
your H89 should be an improvement.
Posted: Wed Aug 23, 2017 1:51 pm
I would think the cam will be different also, as the low horse power was an economy engine.
Posted: Fri Aug 25, 2017 1:28 pm
by RedVB310
How do I find out what head is on my b310s a14, it goes like stink and one of the previous owner's built it, but I have no clue what the head is or what internals it has as the cam is lumpy as and it revs out to 8. Where do I check what head it is?
Sent from my E5823 using Tapatalk
Posted: Fri Aug 25, 2017 1:58 pm
by kb110
Remove the rocker cover and you'll find a casting
Posted: Sat Aug 26, 2017 1:22 pm
by RedVB310
kb110 wrote:Remove the rocker cover and you'll find a casting
Cheers ill look tomorrow as I'll be taking of my intake manifold too to see if im oval port or round port as im looking at going twin carb
Posted: Sat Aug 26, 2017 1:52 pm
No need to remove MAnifold to check ports. Oval ones have a water jacket on the bottom of the manifold and are much deeper in the manifold, post up pics if you want, I am sure you will get opinions on which it is without tearing it apart. A pic of the casting will identify it also I would think.
Posted: Sun Aug 27, 2017 7:22 pm
by RedVB310
Sweet as man I post pictures when I can, didn't have a chance today because of the rain
Re: A14 round port or oval?!
Posted: Sun Sep 03, 2017 10:49 pm
by RedVB310
Hi guys I havw taken some pictures to see if you can help identifying what sort of ports my A14 head has on it and what head it actually is.
