Hi All.
Want to put the Z18 into a 710 coupe and was wanting to know if the L series sump and pump would work. Also if it will what has anyone got out there
Steve
L series sump and oil pump
- aka: Steve
Re: L series sump and oil pump
The oil pumps should be the same.
The L series sump you could use, but you would have to use a L series gearbox and engine mounts to get it to tilt the same way as a L series.
