l18 into 1600....some advice
Re: l18 into 1600....some advice
Would you sway the driveshaft for one of your gearbox Xmembers? Mine was butchered by the neanderthols who owned the car before me.
nosebleed
- Datsun Dreamer
not 100% sure if the spare is a datto one, just looks abit different, will check tomorrow and let you know though.....
found a few parts in the boxes are actually toyota bits,theyv been dumped
I DO ALL MY OWN STUNTS
nosebleed
- Datsun Dreamer
i cant seem to find a number on the box anywhere... theres a 6 by the looks..510BRE wrote:fitting a l18 will need stock 1600 sump and oil pickup with cross member in stock position .... tell us the number on side off gearbox man ......sounds like you got a 71b gearbox this should fit your l18
where would the number be?
nosebleed
- Datsun Dreamer
Bartman wrote:Would you sway the driveshaft for one of your gearbox Xmembers? Mine was butchered by the neanderthols who owned the car before me.
spare crossmember looks like a mazda one... one side is flat and the other side raises up then angles down sort of like a s4 rx7...
MR1200
wat the hell??? stop bein a hater! wats wif baggin on sum one for no reasontorqued wrote:you really have no idea do you?
I reckon give it a month and the your whole car will be back on trade me.
PAINT THE ROADS BLACK !!!!!
- 160jsss
How does 40 bucks sound we out in Kirwee so could pick it up on the way in or out of CHCH
Violet - ??????
nosebleed
- Datsun Dreamer
sweet, means ill have to go through darfield...havent been that way for years..
has it got a fork,shifter,slave and throw out bearing?
- 160jsss
will have a look tomorrow no slave i need one two but cheap to buy new the one on the fj may work
Violet - ??????
