Vanette rotor PCD
all your DIY needs
jeremiahnz
Datsun Driver
Vanette rotor PCD
Post by jeremiahnz »
Hi guys,
Can anyone tell me what the PCD is of the actual rotor for an early C120 or C20 Vanette?
I am after a rotor with a 73mm centre bore and a 4x114.3 PCD.
1965 Bluebird 410
1976 Yamaha RD50
Re: Vanette rotor PCD
The PCD is 114.3.
jeremiahnz
Datsun Driver
Thanks - can you just confirm that the rotor is definitely 114.3, not just the hub on the vanette as I believe the vanette setup is disc behind the hub. I am going to try to use the disc over the hub for my 410.
1965 Bluebird 410
1976 Yamaha RD50
Oh shit sorry, you're right. Yeah I don't know sorry. But I think muppet http://www.nzdatsun.com/forums/memberli ... file&u=192" onclick="window.open(this.href);return false; Might have a used set that he's giving away.
jeremiahnz
Datsun Driver
Cool - I flicked him a message on datsun.co.nz.
If anybody else has a vanette lying around, or can confirm the pcd of the rotor, it would be much appreciated.
1965 Bluebird 410
1976 Yamaha RD50
jeremiahnz
Datsun Driver
In case any one is interested, it looks like they are 95 PCD.
Looking at evo 1-3/vr4 brakes now as they are 114.3 - a bit overkill tho, but they may work
1965 Bluebird 410
1976 Yamaha RD50
actually, and long as your chosen wheels will still fit over them, you can't have too much brakes. I spent ages with shithouse factory brakes, and upgrading them made it like a new car.
jeremiahnz
Datsun Driver
Yeah, I think I'll have to run 15's as a result. Some 14's may still work.
I was probably going to run 15's anyway so it isn't too much of an issue.
Looks like the 280z Master Cylinder is the same bore as the Evo master, and that is a bolt up on the 411 (apart from needing a slightly longer rod)
1965 Bluebird 410
1976 Yamaha RD50
