Datsun Chassis Number Search?????
all else goes here...
Brnwgn
aka: Hayden
Re: Datsun Chassis Number Search?????
Post by Brnwgn »
delux sedans were jap assembled too i think
The deluxe sedans had plastic grills too. (just different to the coupe ones)
The number after the "B110" leads me to believe it's a coupe, or at least not NZ assembled.
My NZ built sedan is b110-001892 and thats a 72. And Simons one is a '70, and his number is very low. Like b110-0000xx.
Brnwgn
aka: Hayden
Post by Brnwgn »
id say simons is a japper with the drum front brakes and its early number and build date
Duffus
aka: Duffus
Post by Duffus »
The car is definately a Coupe as confirmed by a mate who works for Nissan, and is listed as NZ new. If I could sort the wiring issues it would be on the road tomorrow.
510BRE
Area Reps
aka: shane
Post by 510BRE »
i think you need to chuck some photos up bro to put every one out off the missery
Flauski
Post by Flauski »
Brnwgn wrote:delux sedans were jap assembled too i think
Also not true, my old orange one (now Bedes') is a 1200 Deluxe and was assembled by Todd Motors in Thames.
As far as I am aware Bart NZ/Oz/Japanese sedans only came with metal grilles unless they were from a Japanese Sunny Excellent. Even the "facelift" Sunny Deluxe Sedan grille/GX sedan grille is 3 piece and metal. Never seen a factory sedan with a plastic grille.
In terms of plastic grilles The coupes/Utes and early GX models all have the same grille just painted differently and the badges on the front are different even though the grille itself is identical:
Coupe (1 piece, outer raised portion and center raised portion a lighter grey, round "D" in NZ/OZ or "S" in Japan)
Sunny GX Coupe (1 piece, Only outer raised portion of grille a lighter grey,Round "S" with elongated sides)
Ute (` piece, ligher paint around headlights and outside raised portion of grille, rectangle "D" in NZ/OZ or "S" in Japan)
Sunny Deluxe Sedan "facelift" grille was just the same as the Sunny GX Sedan grille (metal , 3 piece)
Sunny Excellent grille (plastic , 1 piece)
The Deluxe sedans had a plastic grill for certin. It wasn't the "scoop" style one the coupes had though. All the SSS sedans had the different type of grills. And they were all build from deluxe sedans.
EDIT, I'm talking about the heater cowl grills. When someone mentioned grills, thats what I though of for some reason........
