1970 datsun 521
- Josh
- aka: SeEn-ThE_lIgHt
Re: 1970 datsun 521
Sweet ride, good to see fab skills in use. Love those Globes. but the other steels are cool too!
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
- gingofthesouth
- aka: Ging
Re: 1970 datsun 521
LOVE these utes. I want one bad. Maybe as my next datto. Will be keeping an eye out for your picsSeEn-ThE_lIgHt wrote:Sweet ride, good to see fab skills in use. Love those Globes. but the other steels are cool too!
- R30 Guru
- Regular
- aka: Jordy
Re: 1970 datsun 521
Excellent wee project you've got there Budd
, shame that the last owners couldn't look after it properly
just thought I'd add that I have New kingpin kits for these utes if you decide to keep the original front end in situ, am looking for a 720 myself to ad to my collection.
Projects Under Development
83 HR30 GT L31ETT
82 HR30 GT VH45DET
67 A30 GLORIA 4DR SEDAN-Resto
http://www.jurassicautomotive.com/" onclick="window.open(this.href);return false;
http://www.facebook.com/JurassicAutomotive
Re: 1970 datsun 521
I have a 1972 521 I have just put an SR20DE into it. It should be alot of fun. These utes are awesome
Re: 1970 datsun 521
Yea cheers, im keen to use the globes but if the offsets dont work out then ill be using the steelies. also i can widen the steelies to fit perfectly.SeEn-ThE_lIgHt wrote:Sweet ride, good to see fab skills in use. Love those Globes. but the other steels are cool too!
then the globes can be my burnout rims.
Rust never sleeps...
Re: 1970 datsun 521
Good job, id love to see some pics. i can see there might be an issue with the bench seat fouling up on the gear stick becasue these gearboxes are abnormally long, did you run a bench seat? did you need to cut the firewall/gbox tunnel to accomodate the sr? what sort of ecu have you used? im hoping to use the factory silvia one, but im unsure if it needs to interface with other car computers to run well etc. it seems like theres not too many wires coming out compared to my 1uzfe.wheel_rx wrote:I have a 1972 521 I have just put an SR20DE into it. It should be alot of fun. These utes are awesome
Re: 1970 datsun 521
sorry dude haven't had a look at this in awhile. I made up to fit using sr bellhousing and tailshaft from an l series short tail box. I have the stock s14vvt computer running seems ok for now, i will put an apexi safc on soon, so i can change a few things. Wiring diagrams are really hard to come by for the sr20de engine. also got custom radiator, and modified the steering to fit the sump.
I had a thread http://datsun.co.nz/phpBB3/viewtopic.php?f=9&t=9243" onclick="window.open(this.href);return false; I should really put it on here. pm me if you need to know anything
Re: 1970 datsun 521
OK heres the latest on the datto, ive been really slack on the website side of things, apologies, but i have however got a fair bit of progress done on the ute.
Sooo i cut both the sills off and found some cute corrosion to deal to, what a surprise
Due to the design both the floor and cab mounts have rusted through...
....so i made up some new mounts
Heres one side all cut out ready for new steel, the whole lover portion of the inner sill was rotten also so that needed replacement.
And this is it almost completed
The other side looked basically the same
Heres an inside shot of the other side
And heres one of the new sills i folded up, not too sure if the profile is correct as the one i removed had been crudely replaced before, as long as it looks close i suppose, hope no one will notice if its out haha
And after stripping the bonnet i found some serious damage, so i guess that's the next on the list to repair
Any way heres most of the crap i have removed so far, decided to keep it all to use as motivation to finish this thing.
On another note, im genuinely considering trying to make a matching well-side tray, so ill keep you posted on that if it ever eventuates,
chur
chur
Re: 1970 datsun 521
thanks for your help man, when i get to the stage of fitting the engine ill surely be in contact.
mean ute too, loving the steelies!
wheel_rx wrote:sorry dude haven't had a look at this in awhile. I made up to fit using sr bellhousing and tailshaft from an l series short tail box. I have the stock s14vvt computer running seems ok for now, i will put an apexi safc on soon, so i can change a few things. Wiring diagrams are really hard to come by for the sr20de engine. also got custom radiator, and modified the steering to fit the sump.
Re: 1970 datsun 521
Stoked to hear you're still persevering with the old girl.
Keep up the good work!
