6cyl L-series Optical distributor
- aka: Dan
Re: 6cyl L-series Optical distributor
interesting.....do say more about your modifications!
To make one work with a Link all you need to do is replace the chopper plate with one out of a VG30E or RB20/30E.
I cut the part the rotor attaches to down and blocked up the hole in the plate covering the chopper plate so I could run mine without a cap.
If you want an optical dizzy you are going to need the shaft to suit as well.
- aka: Dan
is the shaft different to a normal shaft?
Yeap, it's splined on the top for a more postive drive.
This is an optical dizzy.
There is also this odd ball one that also takes a screw on cap but still has a hall effect sensor in it from memory, can't remember where I got it from.
- aka: Dan
hmm....interesting.
those pics are good thanks!
So I'll need a dizzy and a shaft......hopefully the shaft fits into a L4 lol.....if not, could always get that end drive chopped of and somehow fitted to a L4 shaft.
Do you have a shaft out of an engine?
Yeah I've got the one that came out of my motor around somewhere, if the normal L4 & L6 shafts interchange it'll fit.
I've heard FJ20 dizzy internals are very similar, you could probably replace the chopper plate with one of those and it might work?
- aka: Dan
yeah, Ive seen something about that too.....I'm thinking a CA18 plate should fit....looks about right.
FJ20 dizzys would be too hard to find lol
where do you live and what are you up to today? lol
Hah I live in Waltham but I have to go out to my work in Sockburn later on today if that's any closer, send me a text if you want to have a look. 021 161 8827.
- R30 Guru
- Regular
- aka: Jordy
Projects Under Development
83 HR30 GT L31ETT
82 HR30 GT VH45DET
67 A30 GLORIA 4DR SEDAN-Resto
http://www.jurassicautomotive.com/" onclick="window.open(this.href);return false;
http://www.facebook.com/JurassicAutomotive
