datsun118
Datsun Dreamer
aka: .
Re: Kitchs 1200 Coupe - finally some progress.....
Post by datsun118 »
looking so good :highfive:
I had a Bias Valve in the back of the Z, it was fitted before the line split Left and right, tucked up in the wheel arch / drive tunnel area. Just fits in the line and reduces the pressure available to the rear brakes. If you are getting a competition licence and are going to do some events in the car you may be able to get an authority card to have one inside.
grant76
Datsun Nutter
Post by grant76 »
Courtesy of Datsun1200.com:
So you've changed brake types, now has the front brakes are locking up well before the rears come into play. How can this be cured?
There are options for changing the brake bias:
Change rear brake wheel cylinders (larger or smaller). Alternate sizes are available from Nissan motorsports. Or from stock applications. For example, the 510 rear cylinders are 7/8, but bolt in place of the stock 1200 13/16 cylinders. Note that 1200s with drum brakes already have 7/8 rears.
Use an appropriate factory bias valve (aka NP-valve or "proportioning valve"). Note that Datsun 1200s don't use one, while B210 and B310 NP-valves are not part of the brake line "splitter" (brake line warning switch)
Maybe the easiest would be to buy a brake bias controller valve.[/i][/b][/b][/b]
(This is me back again) with the 13/16th rear wheel cylinders in ute diff you should be ok??
Kitch
Post by Kitch »
Thanks for the research Grant.
Might be a bit of a case of "suck it and see"
with all new master cylinder, new lines throughout, S13 front end conversion etc
it is going to be a "new" system anyway, and will just have to see how it goes.
At least I can retrofit the bias valve later
Kitch
Post by Kitch »
Pretty exciting day for me, finally got the coupe home after 10 months.
:D :D :D :D :D :D :D :D
The last things I had to do, was fit the new brake & fuel lines assemble all the rear end up, and fit the new panhard rod mounts to the axle and the body. Clean down, fit wheels etc, realign & trim U-boltd, and undertake the challenging mission of getting it off the rotisserie and back on to the ground/trailer.
My boy Will was stoked to see the coupe back home
(don’t worry child welfare he is holding my beer not his!)
Rear end (note new panhard rod mounts)
LH side Guard/flare
RH side guard/flare
Front ¾
Rear end
New coil overs
LH side (loving the ride height!)
40mm lowering blocks, new U-bolts, new nolethanes, reset leafs, New Koni’s Image
Back tucked away in the garage, after too longer absence
braasmonkey
Site Admin
aka: Braasy
Post by braasmonkey »
Got your txt, no credit at the moment. Very awesome, very jealous! Can't wait to see this beast up and running!! Well done :D
DAT620
Datsun Driver
aka: J
Post by DAT620 »
wow looks awsome man :thumbsup:
Dattochriswagon
Post by Dattochriswagon »
Outstanding bro!!!
2 doors
Post by 2 doors »
attention to detail is awe inspiring, love this coupe, well done.
Kitch
Post by Kitch »
Thanks for your comments guys.
Bit rainey here today, so the golf game I had is cancelled- hmmm, Will wants me to put motor in the coupe...
Might get motivated...
