shit thats getting serious
congrats on getting it going nothing like the satisfiying feeling of everything sounding sweet
well done
- aka: Nick m
Re: Kitchs 1200 Coupe - VROOM VROOM!!!!.....
haha, laptop for tuning? why would I need a laptop!
- aka: Braasy
Good to see the Desktop PC of awesomeness! hehe XDKitch wrote:Havent really progessed much since last weeks startup, although I powered up my ECU, and tried to see if it would fire the new coils.
No luck. dug a bit deeper, and looks like no signal from VR sensor, hence no RPM signal and no spark.
played around a bit with my bodgey bracket, and looks like I had wrong polarity to sensor, and too much clearance to the trigger wheel (was about 3-4mm). need to make up a sturdy bracket to get down to 0.5-1mm.
Also finally got the Toyota TPS working, weird setup. 5V ref signal + Signal return + earth, but took be ages to work out that the 4 pin plug, has a terminal blanked off on the TPS, turned out that one was the variable signal! so the one I thought was signal must have been just the idle reference signal I think, Toyota 4AGE must work differently? or maybe I have done it wrong still? but it seems to work properly.
Bit of a mess, trying to test everything, there are wires for africa.
- Kitch
The PC has two purposes Nick,
A) It is the only computer I have that has a Serial port to connect to the ECU (both my laptops dont)
B) When I am sitting on drivers side, it simulates the weight of a passenger so car sits even when I am working on it
This could be a worthwhile investment since you already mentioned you have laptops
http://www.cablemax.co.nz/Home/tabid/66 ... fault.aspx" onclick="window.open(this.href);return false;
Then you can tune before you race like in fast and furious
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
- aka: Braasy
You can pick up a USB to Serial cable (per jeremiahnz's suggestion) from Dick Smiths or the like, if the mood strikes youKitch wrote:The PC has two purposes Nick,
If you need passenger simulation, I will happily volunteer XD
- Kitch
yeah I got a serial / USB adaptor, but couldnt get it to work, apparently the MS is a bit fussy with the cable adaptor.
had problem installing the drivers for the adaptor too, wasted an hour or so, so gave up and threw in old "clunky" desktop PC
- aka: J
Real? hop eI dont have the same probs with my MS what version is yours?Kitch wrote:yeah I got a serial / USB adaptor, but couldnt get it to work, apparently the MS is a bit fussy with the cable adaptor.
- Kitch
MS2 with V3 daughter board.
got it reconfigured slightly to run onboard BIP373 coil drivers (to drive my Tower coil packs)
tacho output circuit, VR sensor input etc, also I will be running wide band O2 setup.
Yeah they can be a bit temperamental and the drivers often are terrible. We use them at work a lot..... I'll be trying to get one going when I tune my MS as I don't have serial on my laptop and all my 1990's computers are in the binKitch wrote:yeah I got a serial / USB adaptor, but couldnt get it to work, apparently the MS is a bit fussy with the cable adaptor.
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
