J's 620 ute
DAT620
Datsun Driver
aka: J
Re: J's 620 ute
Post by DAT620 »
Bartman wrote:Where the hell did you find that manifold?!!!
Same manifold as a BMC B series because its the same engine essentially. its also got a B series oil pump internals put into the J series housing because I couldnt find a J series replacement one.
cheese910
Datsun Nutter
Re: J's 620 ute
Post by cheese910 »
thats smart
DAT620
Datsun Driver
aka: J
Re: J's 620 ute
Post by DAT620 »
Ok, I'm about ready to molotov this thing down a back street somewhere, Ive been trying to get the 40 solex dialed in, I can either get the idle down to around where it should be 800 rpm or I can get the AFR to where it should be 14.7.
When the idle is at 800rpm the AFR is around 9.8, and when the AFR is 14.7 it idles at 1600rpm and the back 2 cyl miss and show rich fuel soaked plugs the fronts read fine. Also even though I havnt checked with a thermometer the EGTs are way hotter then what they should be, but that makes sense because of its current running condition.
The timing at idle is 10deg btdc, checked with a timing gun.
The next thing I'm going to look at is air leaks around the inlet manifold and possibly some colder plugs.
dirtyleppa
aka: leppa
Re: J's 620 ute
Post by dirtyleppa »
wouldnt the AFR be lower at idle and increase with revs and load applied?
DAT620
Datsun Driver
aka: J
Re: J's 620 ute
Post by DAT620 »
dirtyleppa wrote:wouldnt the AFR be lower at idle and increase with revs and load applied?
No stachiometric burn is 14.7.
you actually want it to drop a bit below that when you rev it or else it will detonate max horsepower is between 12.6 and 13.7.
but If i cant get it to idle right theres no use even trying to get the progression circuit dialed in.
DAT620
Datsun Driver
aka: J
Re: J's 620 ute
Post by DAT620 »
Paint stripping :D
ging
Re: J's 620 ute
Post by ging »
DAT620 wrote:Paint stripping :D
looking good j
13coin
Datsun Dreamer
aka: Bkk
Re: J's 620 ute
Post by 13coin »
Nice work.
DAT620
Datsun Driver
aka: J
Re: J's 620 ute
Post by DAT620 »
Damn you people reviving my thread showing me what a lazy ass I am grrrr :lol: (nothings been done further since last post)
