Datsun Parts:
1 x 13'' Steelie tyre is stuffed $5
2 x 13" Steelies matching pair tyres are stuffed $10 SOLD
Throttle linkages from 180B may fit other L series models?? $5
Heater core and heater controls from 180B unsure if core is in good cond $20
180B manual pedal box may fit others $30
910 service manual free to a good home
180B choke cable and bracket may fit others $5
Chrome number plate surround $10
2x Internal regualtors from 180B both have different plugs $5 each
180B fuel flap no lock $5
Nissan Stuff:
Shortnose R200 LSD 5x1 axel stubs 4.11 ratio Local buyers only please!
Looks like it has been dropped at some point a few chips in the rear cover doesnt leak oil also missing one stud $100
CA18DET Turbo Manifold Heat Shield $10 SOLD
CA18DET Inlet Manifold Braces $10
Assorted RB and CA plugs and valves oil pressure sensors etc $10 for the lot unknown cond
S14 PFL Front Caliper(just 1) I'm pretty sure the other one is Barts somewhere if i can find it the pair will be $30 otherwise just $10 for the one
RB20DET Turbo oil drain $5 SOLD
T25/g/28 Turbo oil drain brand new never used $10 SOLD
Nissan bonnet struts x5 unsure of condition $20 for the lot
RB sandwich plates x3 the half one is a bit bent but should be easy to straighten $20 for lot
Nissan gearbox crossmember has an A stamped into it under the rubber mount unsure what its from $20 SOLD
CA brackets and under drive pully(I think?) $20 for the lot SOLD
Prices can be negotiated want all these gone asap so will biff out most of it it doesnt sell. Cheers
