Time for an update! Its been a while.
Bought a 14" electric fan for my VL radiator, and Dan so nicely attached it for me
Got a thermo fan switch as well, I'll be going to A1 after work to get them to weld a fitting in so it can be fitted.
Scored a 260c gas pedal assembly from Brock as I seemed to have misplaced mine havn't test fitted it yet but hope it works all good.
Also got the fuel sender from the 260c Brock and John wrecked as it has the extra sensor for the low fuel light. The strange thing is that my car is all wired up for it the loom, dash etc all it needed was the sender with the extra wire on it! 610 on left 260c on right
Scored a 180B SSS center console and SSS loom off vegie earlier this year too got a rough pic of it in the car looks pretty good!
Have a magnetic sump plug to put in when I'm at Dans next
Was over at Dan's with Bart on monday, wiring is pretty much done! Even got to see all my electrics work which was mega awesome as I havnt seen anything work since I started pulling it apart 5 years ago and it was sitting for a while before I got it. Alarm is pretty much finished and its rather loud..
So next on the list is fuel lines.... anyone keen to lend a hand with that??? Will be able to start it once fuel system is done as well as a few other things
