Was used in the 80's as a Super car Build for going fast at circuits such as Pukekoe and Manfield.
Was told it used to do over 230kph - by old driver.
Is quite rare now days being twin cylinder - most are single - Is a Yamaha 250cc 2 stroke.
Heres a few things about it
5 speed box
Disc Brakes all round
Side pod is actually the fuel tank - Scary if you had someone drill you in the side
Seating position is on a queer angle due to engine width.
Used to run Methanol -but the carbs were obviously to big and we put 250cc yamy carbs on.
Fuel pump looks like a datto one and works of a cam on the rear axle - IE if your not moving you'll run outta gas.
Ive drivin it a couple of times - trys to lift front wheels off the ground and three wheels (front off the deck) round most corners on a sprint circut.
Ill update this wheel ive got it running and take some vids
