SSS cylinder head on Lseries
maddat
Post by maddat »
hey guys
hope someone could help me..
hw cn we differentiate
a SSS cylinder head over a standard head
on L16/L18 Lseries engines..
is valves any bigger ??
inlet port size
what is the correct valve lash be on L16..if it has a A87 head with L18 cam..
umm second question is
wat should the correct oil pressure when idling on L16??
thanks alot in advance..
cheers
nathan
chch
160jsss
Re: SSS cylinder head on Lseries
Post by 160jsss »
Hi Nathan
I'm being a arse but get this book you need this book as a Datsun owner it will keep you reading it over and over .
I was looking for mine to answer your question but can't find my dog eared oil stained copy
http://www.trademe.co.nz/motors/car-par ... 776508.htm" onclick="window.open(this.href);return false;
Violet - ??????
maddat
Post by maddat »
thanks man
seems like me question was abit confusing
but i got this link in the end..
http://www.olddatsuns.com/html/tech/head_ID_2.htm" onclick="window.open(this.href);return false;
i also bought a SU carb setup will install it soon..
thanks alot again
For what it's worth, most of the A87 heads I've seen have been closed chamber.
