D1RTY6's C331 Gloria
- brocky41
- aka: Brocky
Re: D1RTY6 's 1978 C331 Gloria SGL-E
Pretty sure we got one here dude ill check today - is from the blue car again.
- D1RTY6
- aka: Nathan
Choice will text you tonight.brocky41 wrote:Pretty sure we got one here dude ill check today - is from the blue car again.
update on the car.
I got head gasket sorted Saturday torqued down and every thing back on. got excited and tried starting it and nothing. It just keeps turning over and over not even sounding like its going to kick into life
As far as i can tell everything that i pulled off has been put back on, and I've exhausted my knowledge on trying to fix it as i know little about these motors.
any ideas what it could be??
Possibly time for a engine conversion as i have a feeling these L-Series don't like me.
Nathan
How much of the electronics did you pull off, did you remove the dizzy etc?
- D1RTY6
- aka: Nathan
Yea removed the Dizzy but put it on the same as last time when i got it running. its getting spark no problem. also getting fuel.DJZ wrote:How much of the electronics did you pull off, did you remove the dizzy etc?
if I cant get it going would you mind popping round after work one day this week and ill flick you some cash or beer or something.
- brocky41
- aka: Brocky
Check your firing order and make sure leads are round right way, also throw new plugs in l series can be bitches for eating plugs.
Stick a timing light over it.
- D1RTY6
- aka: Nathan
Have also done thistorqued wrote:Stick a timing light over it.
Have also checked firing order. will get new plugs this weekbrocky41 wrote:Check your firing order and make sure leads are round right way, also throw new plugs in l series can be bitches for eating plugs.
Timing light is flashing in pretty much the right spot when you are cranking it? Are the plugs wet when you take them out?
There's only 3 things you need for combustion and it sounds like you've got them all so that would make me think the timing is wrong.
- D1RTY6
- aka: Nathan
DJZ wrote:Timing light is flashing in pretty much the right spot when you are cranking it? Are the plugs wet when you take them out?
This thing is still beating me .......
I've chucked a timing light over it, its hitting pretty much the right spot. plugs are a little wet when i take them out, forgive me for my ignorance but that would indicate what?
anymore info would be much appriciated
Nathan
- D1RTY6
- aka: Nathan
Quick question
If the inlet cam lope is gong down in compression stroke and the exhaust up on cylinder one, the crack pully should be reading TDC yea?
if so i think i found my problem but cant figure out how it happend
