I have started to put my coupe dash in to a sedan, pulled the wires out of the main round plug and re-wired as the the sedan to coupe wiring picture on datsun1200.com. only thing is i have a couple of different wires... i have 2x black wires and a yellow/black no yellow/blue and no red/yellow wire. when i turn the key to on only the charge light faintly comes on, but if i try to put the headlights on all my indicators come on and stay on??? tired swapping a couple of wires here and there but still does the same thing?
anyone one found this when wiring a coupe dash into their sedan?
HELP wiring coupe dash
jas1200
- aka: Jas
Re: HELP wiring coupe dash
Hey, i,ve just done this.....This is how mine is wired, its all working.
If you number the plug 1 at top to 12 clockwise, mine is like this.
1 yellow/ white
2 yellow/ black
3 black
4 red/white
5 yellow
6 green
7 blank
8 white/red
9 green/ red
10 green/ blue
11 green/ black
12 black
1 yellow/ white
2 yellow/ black
3 black
4 red/white
5 yellow
6 green
7 blank
8 white/red
9 green/ red
10 green/ blue
11 green/ black
12 black
Ok sweet ill try this tomorrow and see if i can get it to work
Tried it with this plug setup but i have no head lights, and my indicators all light up when i turn the headlights on.. Only lights on dash are faint charge light, but im now getting high beam light
Any ideas?
Any ideas?
jas1200
- aka: Jas
Did you go clockwise when looking at the front of the plug, do you have the same colour wires as I do?
Looks like I'm going to have to get my loom out and take some pictures. Give me acouple of days.
yeah I did it the same as yours and yep all same colours? yellow/white in number 1 slot all the way round the the black in the 12 slot not sure whats going on??jas1200 wrote:Did you go clockwise when looking at the front of the plug, do you have the same colour wires as I do?
Thanks Blair that would be greatBlair wrote: Looks like I'm going to have to get my loom out and take some pictures. Give me acouple of days.
alright managed to get most of it working (all dash lights, charge light, high beam, indicators) this is the way i wired the plug
1 Y/W
2 Y/Black
3 G/Black
4 G/Blue
5 G/R
6 G
7 Blank
8 W/R
9 Y
10 Black
11 R/W
12 Black
problem is i cant get the fuel gauge to work (does the car need to be running for this to work?) apart from that I'm good to go.
I tried changing the Yellow and Red/White wire around which resulted in my LH fr lower indicator/park light wires melting! Not that much fun looking up and seeing smoke come out of the bonnet!! so i put the wires back to the setup above and decided to call it a night.
any ideas?
1 Y/W
2 Y/Black
3 G/Black
4 G/Blue
5 G/R
6 G
7 Blank
8 W/R
9 Y
10 Black
11 R/W
12 Black
any ideas?
What is the best way to hook up the rev counter? I cant find the b/w wires in the loom that you are suppose to use. Should i just wire it directly to the coil instead or is there a better way to wire it?
- kartboy
- aka: Hayden
The black white wire goes to the coil, rev counter should be wired to the negative side of the coil i believe.
