First off a bit of history of the car. It's been in the family since around 1996 when my brother bought it off one of his mates.
It was featured in "4's and rotary's" back in the early 90's and was one of the first fj20 conversions done in a 510 in Australia. Pics from shoot here -> http://www.turbocreations.com/fj20/white1600/" onclick="window.open(this.href);return false;
After my brother blew up 3 motors in it, he sold it to my dad not running, my old man picked up a motor from a local importer and chucked it in to get it going.
He's slowly been replacing painted stuff (which was popular in early 90's when the car was built) with chrome stuff.
Few specs
- fj20et & 5 speed with microtech MT-8
- High flowed T3
- W2A intercooler
- r200 clutch pack lsd
- R31 silo seats retrimmed
- 240k struts with hilux 4 spots coilovered in the front.
- Falcon rear discs and brakes.
Currently i'm in the process of putting a FMIC, new rad, turbo, manifold, Electric water pump etc in it.
Pictures
As it sits currently (before I pulled it apart)
Some pics from the current work I'm doing;
Checking grill fitment
New rad
Rad and IC
Will be using a davies craig water pump to give more room to mount the cooler back
Forgot to mention, also picked up a new forged motor for a steal, so putting that in at the same time
Testing some extractors I had lying around that I'd got off an S12 years ago, they were going to work until I discovered the impeller wheel on the turbo was damaged, looks like it ate a nut or something. If I rotated the housing on the turbo it would fit nicely.
Marking bits to trim with grinder to let the IC sit nice and straight and against the grill
Now sits flush
Chopped this part of the front pulley off (think it's power steering) to give thermo fan clearance
More marking for cutting
Grinding using cutting wheel
Cleaned up with grinding wheel
Another check to see that chrome goes back on
Were it's currently at is, waiting on my mate to finish cutting and rewelding the inlet manifold to suit a bigger TB and change the angle of where it points (to sort IC)
Also bought a T28BB off a jap spec S15, waiting on an S12 exhaust manifold and adaptor to come which will fix that side up. Didnt want a big turbo, just wanted something responsive for the old man to putt around with.
And just working on radiator mounts etc at the moment as it didn't come with any.
