I'm rebuilding a set of twin Hitachi / SU carbs at the moment and am after a couple of bits if anyone has spares
I gave a mint set of these away a while ago haha - gutted
The parts I'm looking for atm are:
The screw assembly that attaches the arm to the fuel nozzle at the bottom of the carb - there is a little machined spacer in there (part 32) that I'm missing and the original screw and washers would be nice too
There's also a fuel return bar that connects to both carbs and is bolted to one of the main mouting studs on each carb. It's made of about 10mm tube (circled), and the standard fuel line that bolts to the intake manifold studs (circled)
I'd also be keen on a standard air filter box if anyone's got one lying around!
Thanks
Shannon
